ESXi and multiple NICs
Discussion in 'Virtualized Computing' started by Yakyb, Jul 14, 2009.
  1. Yakyb
    Yakyb Limp Gawd
    474
    Mar 13, 2008
    how does ESXi handle multiple nics if i had 4 nics in my machine could i assign each one to an individual VM essentially having a NIC each as opposed to sharing one?
    sorry if this is a little vague im just trying to get my head round things before buying a new machine
  2. vapb400
    vapb400 Gawd
    786
    Sep 19, 2004
    Short answer, yes.
    I just started working with ESXi yesterday, but essentially you create vswitches, and treat your Physical NICs as uplinks.
    The physical NIC is just a gateway, it is all about how you assign your vswitches
    This doesnt illustrate what you are asking but it shows how you apply vswitches to a NIC
    [​IMG]
  3. lopoetve
    lopoetve Imhotep
    28,965
    Oct 11, 2001
    Bingo. Each vSwitch can have combinations of Virtual Machines, Service Consoles (esx classic only), and vmkernel ports - just like a real switch.
  4. B1zz
    B1zz Gawd
    932
    Aug 1, 2003
    also, and correct me if i'm wrong but if there is network traffic between 2(or more) hosts on the same vswitch, that traffic never actually leaves the hardware or touches the actual physical switching fabric....pretty awesome if ya ask me :cool:
  5. lopoetve
    lopoetve Imhotep
    28,965
    Oct 11, 2001
    two or more VMs - it has to hit the hardware for hosts, as they're separate boxes, but yep - on the same vswitch, VM traffic is all internal.
  6. Yakyb
    Yakyb Limp Gawd
    474
    Mar 13, 2008
    interesting thanks
  7. SpaceHonkey
    SpaceHonkey Gawd
    983
    Jan 25, 2007
    I thought this was dependant on using the VMXNIC type - yes/no?
  8. lopoetve
    lopoetve Imhotep
    28,965
    Oct 11, 2001
    Nope - independent of the device type as it's at the ESX layer :)
  9. Berg0
    Berg0 [H]ard|Gawd
    1,038
    May 16, 2005
    ESXi vswitch is vlan aware, correct? vlan tagged traffic also stays on the logical switch?
  10. lopoetve
    lopoetve Imhotep
    28,965
    Oct 11, 2001
    Should be, but that's at the extent of my network knowledge in general. They're definitely vlan aware though. :)
  11. B1zz
    B1zz Gawd
    932
    Aug 1, 2003
    if youre referring to whether it'll do vlan trunking (eg dot1q) and keeping seperate broadcast domains separate within the vswtich on the ESX "layer" i'm pretty sure that it does, as it would be entirely possible(although me personally i wouldnt do it this way unless required by some sort of business or technical constraint) to have 2 VM servers or test boxes or what have you that need to stay on their seperate vlans but reside on the same physical hardware sitting in the rack.
    or is that TMI? :p
  12. lopoetve
    lopoetve Imhotep
    28,965
    Oct 11, 2001
    99% sure that it does :)
