ESXI 6 on Braswell....
I am attempting to assemble a cheap vm box for my amusement and learning. if everything works, it may become the pfsense / xpenology nas / vpn gateway box at my parents house...
Setup is:
Asrock n3150m matx board with 1.10 bios - Celeron n3150 and Onboard grpahics
Onboard audio and ports are off, onboard realtek lan is on
Added 16gb Gskill ddr3 @ 1600 (Had extra here)
Spare 128gb kingston SSD v300
Spare Intel Dual Lan card
Spare Sil3124 pcie card @ 6.6.0.0 bios in SATA (non-raid) mode
Spare 350w antec psu
New Corsair 200R case
As it does not have a comparability module in the bios, I could not get Hyper V Server 2012 R2 or Server 2012 r2 with Hyper modulev to run. Hyper V server 2016 p3 works.
I installed windows 10, VM Workstation 12 works flawlessly with it.
Xen 6.5 works,
I would prefer ESXI 6.0 to the above mentioned units.
Off a usb stick created with rufus 2.3, unmodified esxi hangs on "Relocating modules and starting up the kernel…” and the "shift+o" and entered "runweasel ignoreHeadless=True" suggested here (http://robwillis.info/2014/01/dell-...elocating-modules-and-starting-up-the-kernel/) does not help.
After much screwing around, i figured out how to patch the ESXI iso, but still not luck as it still hangs on the "Relocating modules and starting up the kernel…”
I downloaded the latest iso of esxi 6.0 to c:\exsi (pardon the error) and downloaded the following drivers from here: http://www.virten.net/2015/02/how-to-install-esxi-on-5th-gen-intel-nuc-nic-and-ahci-workaround/ as the nuc has similar specs to my setup (minus the dual intel lan card which is supported in version 6). I then used VMware Front Experience: ESXi-Customizer-PS in Power CLI to patch the iso:
"PowerCLI C:\exsi> .\ESXi-Customizer-PS-v2.4.ps1 -pkgdir c:\exsi
Script to build a customized ESXi installation ISO or Offline bundle using the VMware PowerCLI ImageBuilder snapin
(Call with -help for instructions)
Logging to C:\Users\messe\AppData\Local\Temp\ESXi-Customizer-PS.log ...
Running with PowerShell version 5.0 and VMware vSphere PowerCLI 6.0 Release 2 build 3056836
Connecting the VMware ESXi Online depot ... [OK]
Getting Imageprofiles, please wait ... [OK]
Using Imageprofile ESXi-6.0.0-20150902001-standard ...
(dated 09/03/2015 14:04:26, AcceptanceLevel: PartnerSupported,
For more information, see http://kb.vmware.com/kb/2124725.)
Loading Offline bundles and VIB files from c:\exsi ...
Loading C:\exsi\net-e1000e-3.1.0.2-glr-offline_bundle.zip ... [OK]
Add VIB net-e1000e 3.1.0.2-glr [New AcceptanceLevel: CommunitySupported] [OK, replaced 2.5.4-6vmw.600.0.0.2494585]
Loading C:\exsi\e1000e-3.1.0.2-glr.vib ... [OK]
Add VIB net-e1000e 3.1.0.2-glr [IGNORED, already added]
Loading C:\exsi\sata-xahci-1.27-1.x86_64.vib ... [OK]
Add VIB sata-xahci 1.27-1 [OK, added]
Exporting the Imageprofile to 'C:\exsi\ESXi-6.0.0-20150902001-standard-customized.iso'. Please be patient ...
All done."
I created another boot usb key with rufus 2.3.
I get the same issue as it starts up and hangs at "Relocating modules and starting up the kernel…”
Any suggestions?
Otherwise I am going Win10 with a connection limit hack and VMWARE workstation 12 for pfsense, xpenology,etc
VT enabled in BIOS (or is that the compatibility you were mentioning?)
How long did you let it sit at that page?
i wonder if it would work if you disabled the onboard gfx. I had the same issue on an evga x58 motherboard and never did figure it out.
Why not use VMWare Player to install ESXi to a USB drive, then move that USB drive to your system?
on the x58 system it would still hang on at the same place.
gave up on vsphere and went with hyper v
hyper v server 2012 r2 and server 2012 r2 with hyper v have issues with this cpu/chipset
server 2016 p3 with hyper v is working for the moment
oddly enough, vm workstation 12 works fine
