This has been annoying me to no end, and now it's kind of getting serious.
Setup:
Two Dell R810 hosts as mentioned in previous posts. Using 4 integrated Broadcom NICs and 1 Intel ET2 Quad PCIe NIC.
Management is setup to run on vmnic0 with standby on vmnic1.
vMotion using vmnic1 with standby on vmnic 0.
VM traffic on vmnic2/3 using LACP.
iSCSI using all 4 Intel ports (vmnic 4/5/6/7).
Dell OMSA Agent for ESXi installed.
Situation:
I can't for sure validate this sentence, but I really think since I've installed the OMSA agent, I've had a LOT more problems on reboot of these two boxes. At this point I'd say on any reboot since then the management network does not come back up on reboot - you have to restart management from DCUI. Works as soon as you do that. Next reboot - same deal.
So TL;DR - Management network is completely fubar after restarting an ESXi host. Restarting mgmt fixes it. What the eff gives?
Setup:
Situation:
- Restart a host.
- Configured DRAC for Dell vCenter Plugin.
- When it comes back up, some services are excruciatingly slow to come back up - USB Arbitrator comes to mind as one that sat there forever.
- After ESXi loads again, the management IP has changed to the Dell EQL Heartbeat IP. I have no idea why this happened. Absolutely no changes were made aside from assigning an IP to the DRAC.
- Tried restarting the management network, assigning management to the correct NIC/IP, but it fails to set it. Will NOT let me set it back to the original IP of the host. Set it to another IP in the same address space.
- End up resetting network config entirely. Able to set host back to the original IP, but vCenter will not reconnect to it. Also can't log in to host directly through client - it does show 'loading inventory' but will not progress. Host does ping at correct IP.
