esxi 5 --- question
ToddW2
I`m building a new system to run win7, and OSX on.
My original plan was to run win7+workstation and run OSX in there... now I`m thinking what about running ESXi 5 and then I could run a couple others.
I need to use this systems displays for OSX, and Win7, so I`m not sure if that's possible with ESXi to use the VM "Local" on the host machine ?? If not then I the workstation solution it is...
If you use the PC as a esxi host you will need another pc to connect to it's VM's with. Think Remote Desktop or Workstation/VSphere clients. You cannot work with the VM's directly on the host.
Thanks guys.
I have a Workstation 9 license and will go that route :D
