Is there any real benefit to using this? I have a 5.5 environment setup and enabled LACP on my Production distributed port group with the mode set to Active. I also enabled LAG on the switch ports going to each ESXi host. There are two 1 GbE NICs per host. I ran an iperf test between two VMs on different hosts with 10 parallel sessions, and the speed is still only 900+Mbps. The distributed port group is set to IP Hashing, and I tried several different hashing algorithms on the switch.
