- Feb 8, 2005
I "upgraded" my ESXi rig from 5.1 to 5.5 recently. The first thing I noticed was how incredibly sluggish everything ran. Apparently, ESXi can no longer handle a ZFS pool shared via NFS unless you disable sync. That only took 3 hours to figure out. Next, I noticed that my backup server wasn't working. Turns out that passing through the SATA controller on my X9SCM no longer works at all. Oh, sure, it passes through to the OS, but it can't be used. Windows gives it a code 10, and Solaris can't see anything plugged in to it. I tried it in the fat client and in the web client.
Which, by the way, who's genius idea was THAT hunk of junk?
A) It creates VMs only usable by the web client.
B) It takes over control of all VMs on that host so that you can't modify anything EXCEPT through the web client.
C) It does B even if the vCenter Server Appliance is turned off. The only way to fix it is to reboot the host.
D) It utilizes 4GB+ RAM on the resource-limited server instead of 65MB of RAM on a client.
E) It takes FOREVER to do anything. Every time I click a button, I'm forced to wait several seconds for the page to update. (And this when it's the only VM running!)
F) You can't open the console unless the VM is turned on - So much for hitting keys early in the boot process!
I am VERY thankful I decided to install to a different USB stick instead of overwriting my 5.1 install. Fixing my backup server was as simple as plugging in the old stick, creating a new VM, passing through the controller, and running an installer.
Looks like I'm sticking with 5.1 for now. Maybe next time I'll consider the HCL as gospel. There's a reason my motherboard's not certified for 5.5!
