Hi,
I have build a home server with the following hardware:
- Supermicro X10SLL-F
- Intel Xeon E3-1230v3
- 32 GB RAM
- Logilink firewire PCIe card
- Intel PRO/1000 PT dual port PCIe NIC
- 4GB USB stick to boot ESXI
The problem is that ESXi 5.1 will not boot when the machine is connected to the home LAN on any of the 4 available NICs!
The ESXi boot process starts and it will stop right after loading "s.v00" with a fatal error 33 (inconsistent data). If the network cable is not connected, this never happens and ESXi 5.1 boots like it should. The same happens when running the ESXi 5.1U1 installer (ISO downloaded from the VMware site)
I have tried different USB sticks, even installed ESXi on a harddrive, but always with the same result.
ESXi 5.5 does not give those errors, but this version is not usable for me, because the PCIe passthrough seems broken. VMs will not boot when the PCIe card is passed.
My workaround for now is that I unplug the network cable during the boot process and insert it once the boot process loaded all the files and the yellow screen appears. Always works, but would be nice to restart the server in a lights out environment without this hassle.
Paul.
- 32 GB RAM
Paul.
