ESXi 5.1 ISCSI setup?
Silver565
I have an ESXi 5.1 server connected to an ISCSI unit. I'm attempting to reduce latency issues. How has everyone set their units up?
I currently have two physical NICs with two VMKs attached to each. which map to two ports on the ISCSI unit(each VMK is on a different VLAN as each port on the ISCSI unit is separated).
Should I be combining both NICs into one vSwitch?
Are you using a VSS or VDS? Are you allowing all VLAN traffic to the VSS? What kind of latency times are you seeing?
How much latency? I seriously doubt the latency is being caused by your network config if it's high. Most likely the iSCSI unit.
Here are a few things we need to know:
1)What is the iSCSI target(name brand or homebrew)
2)Jumbo Frames
3)What types of disks
4)What type of path selection policy
