My current build uses an intel board with one builtin PATA connector. I have ESXi installed on a laptop IDE drive, connected to that port - datastore installed there as well. My soon to be replacement system will be a supermicro x9scl-f, which has no PATA connectors. I like the laptop drive, since the SAN is on 6 3.5 inch sata drives, and I'd rather not put another SATA full-size drive in that case, so the choices are: get a laptop sata drive, plug in my low-end 4-port sata HBA and connect the laptop drive to that, or get a (cheap as possible) PATA controller that will go in a pci-e slot (not even sure there is such a beast?) I suppose I can get a 16 or 32 GB SSD and use that instead of a laptop sata drive. Any thoughts?
