Yes and no - You HAVE to have VT if you even want to run something inside ESX in workstation. In addition, ESXi requires 1gb of ram for the initial ramdisk or it will psod.
The xtravirt method works for 302/303/35/40(no booting vms) and 2.5.5/2.5.4 if you need them.
I'm one of the local ESX / vmware guys, so drop me a line if you need something.
You work for VMware? How about getting me into the 4.0 private beta?
Thanks for the replies guys. Basically i plan to build an environment in a box. Like sabregen. Before i read his thread i had no idea it was possible. Started goggling endlessly and the lights started turning on.
I really interested in learning about the ESX features. Even if it for the trial period i'm fine with that. I do have processor picked out that do support virtual technology.
What you mean by xtravirt method works for 302/303/35/40(no booting vms) and 2.5.5/2.5.4 if you need them?
Can i use that guide to setup ESX in workstation or do you recommend a different one? I will most likely be using the most current releases from vmware.com when i do get around to purchasing all the hardware.
Wish I could![]()
Was worth a shot.
I have vmware esxi 3.5 build 123629 running in vmware workstation 6.5. I cant install any 64 bit operating systems it says "attempting to load a x64 operating system, however this cpu is not compatible with x64 mode."
I have a c2d 6750 with VT enabled, and I am able to install x64 OS's under workstation 6.5 but not in ESXi. I cant seem to figure it out anyone know the answer?
Recreate the VM after you enabled VT.
No same error unfortunately, still cant install x64
did you recreate the Workstation ESX vm?
dunno, was curious if that mattered at all since we had 4 layers of virtualization. I'm on XP32bit, so I guess not.
This is honestly too slow to be usable - just run something small in it for proof of concept or learning.
Im assuming this would work if it was on a dedicated box, no? I think the problem is that its virtualized.
I can install x86 operating systems, its slow but bearable.
lol maybe i7 would make it tolerable
