koolaidkitten
- Apr 28, 2006
I'm getting this error when I try to add one of my drives to storage
"Call "HostDatastoreSystem.QueryVmfsDatastoreCreateOptions" for object "ha-datastoresystem" on ESX "192.168.8.1" failed."
This error appears on any of the 3 SATA controllers I plug it into. (Samsung 2TB HD204UI btw)
I have 3 other drive models just like this one and they got added without any problems, I also tried adding a different model drive and it got added just fine. The only thing that makes this drive a lil different form the rest is that it used to be part of a RAID-0 on a SIL3114 controller within Windows2003. It's sister drive got added just fine. This leads me to think that there is possibly some sort of remnant left over from the RAID pairing and it is giving ESX shit about it. I formatted the drive in Windows but it is giving me the same error. I also did some check disk and some data dumping to it to check for errors and it seems clean. Can anyone suggest something that does a 100% to the bone format? I'm thinking Windows is just not doing it all the way or something.
