Okay,
So I'm having a very odd issue with my eSATA hard drive.
The model # is a Samsung HD501LJ (500GB, SATA2) within an Antec MX-1 external hard drive. It is connected via eSATA to the rig listed below in my sig.
Prior to today, it was working fine and never had any problems. That is; transfer speeds were consistently topping out at around 70 MB/s, and no stuttering would occur.
However today upon transferring files from it to my internal 1TB drive, it began to exhibit a strange issue where it caused the system to "stutter" every couple seconds. That is - the mouse cursor freezes, any music playing begins to loop ... and then it goes away. Same happens again and again until the transfer finishes.
I ran HD Tune and got these results:
The only major piece of software I have installed most recently was VirtualBox - I immediately uninstalled it after this problem began with said hard drive, but doing so resulted in no discernible difference. I have not changed any overclock settings or done anything radically different than I usually do (software or hardware wise) in the past couple days.
Notable pieces of software installed:
Ad-Aware 2008
Acronis True Image Home
avast! Anti-Virus
Any ideas as to why this is happening? Thanks in advance.
Ad-Aware 2008
avast! Anti-Virus
