errr...3000+ overclock?! 3dmark2001 results inside..
dstrat
Here's the thing got an CBBID 0451 3000+ winnie on an Epox 9NDA3 mobo. Now with it at 2.4ghz (267x9) i am getting 11 000 marks on 3dmark2001se...iirc, at 3500+ speeds, i was getting 9000 - wtf is going on! My 2600+ battered these benchmarks..
Bit of info -
CPU Properties:
CPU Type AMD Athlon 64 3800+
CPU Alias Winchester S939
CPU Stepping DH7-D0
CPUID CPU Name AMD Athlon(tm) 64 Processor 3000+
CPUID Revision 00010FF0h
CPU Speed:
CPU Clock 2402.52 MHz
CPU Multiplier 9.0x
CPU FSB 266.95 MHz (original: 200 MHz, overclock: 33%)
Memory Bus 218.41 MHz
CPU Cache:
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
Motherboard Properties:
Motherboard ID 11/01/2004-nForce-6A61CPAHC-00
Motherboard Name Unknown
Chipset Properties:
Motherboard Chipset nVIDIA nForce3 250, AMD Hammer
Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS)
Command Rate (CR) 1T
SPD Memory Modules:
DIMM1: Corsair VS512MB400 512 MB PC3200 DDR SDRAM (2.5-3-3-8 @ 200
MHz)
DIMM2: Corsair VS512MB400 512 MB PC3200 DDR SDRAM (2.5-3-3-8 @ 200
MHz)
BIOS Properties:
System BIOS Date 11/01/04
Video BIOS Date 04/03/04
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message 11/01/2004 For nForce3 Ultra Chipset
DMI BIOS Version 6.00 PG
Graphics Processor Properties:
DirectX 4.09.00.0904 (DirectX 9.0c)
Video Adapter ATI Radeon 9800 Pro (R350)
GPU Code Name R350 (AGP 8x 1002 / 4E48, Rev 00)
GPU Clock 378 MHz (original: 378 MHz)
Memory Clock 338 MHz (original: 338 MHz)
Sensor Properties:
Tsystem 32 °C (90 °F)
Tcpu 37 °C (99 °F)
Fcpu 3375 RPM
Vcore 1.44 V
Vaux 1.49 V
Vio 1.58 V
Thanks in advance,
Thought i'd just say, i'm scoring HALF what similar systems are, something wrong with my oc somewhere?
AMD 64Bit CPU Driver? Updated GPU Drivers?
You should be double that definatly.
