Error Loading Operating System - Help
CoRPS
Alright, after OCing, and checking Prime, it was stable.
So I went to up my FSB to 215, I guess my RAM can't go that high, it gave me the big long beeps.
So I reset CMOS and boot up.
put my normal BIOS settings back on.
And after 'Verifying DMI Pool' it tells me it can't load the operating system.. What should I do?
Edit: Specs:
DFI NF2 Infinity Ultra
AMD XP-M 2400+
2x256 GeiL PC3200
1x512 HyperX PC3500
Double check your IDE configurations are right...along with boot order. If all that seems fine, bood from the OS cd and try to run a repair.
Btw.
On my post screen it says
"Display switch is set incorrectly"
#1 What is that?
#2 Is that the problem?
