In the past I have configured a PowerVault SAN using two separate subnets and VLANs. This was Dell's recommended setup. I am guessing this is for the multiple paths and load balancing to work correctly. I also setup two 10Gb switches stacked with LAG. On the ESXi host, it is a single Standard vSwitch with two VMkernels. Both on a different subnet. (10.10.10.15 and 10.10.11.16). In NIC Teaming both are set to Active with IP Hash.
Would this be the same configuration for an EqualLogic PS6210X? I am reviewing someone else's work and they have eth0 as 10.0.0.10 and eth1 as 10.0.0.11. I would think they should also be on different subnets.
