EqualLogic & ESXi 5.0
jenuster
Anyone here that works for/with Equallogics? Their support is telling me ESXi 5.0 & Dell Equalogic's currently are NOT supported.
Good Link.
The SAN is on the HCL on the VMware website. However, the storage vendor is iffy about the whole thing. Their response when I asked them the question about compatibility was "if you have any problems, we can try to help"..I'm just going to wait till Dell explicitly supports it.
Does HA work in a mixed cluster? ESX4 & ESXi 5 for example. I know there are issues with FT.
It should. As soon as you add a vSphere 4 host to a vCenter 5 server it gets the new HA agent. Just watch your hardware versions on the VMs.
If it's on the HCL, a certification was submitted for it, and it passed - that's run by the vendor. If they're being iffy though, I'd hold off- I'll check tomorrow.
sweet, we've got a dell guy on here now :) I'm from the other half of this equation :)
I've not been here in a long while lopoetve, but the thread popped up in my Google Alerts. If I can be of help feel free to email me.
Thanks everyone. Upgrade went well, I had no issues migrating to ESXi 5.0 and no issues with the Equallogic.
Update: It looks like there are issues with the Equallogic and MD series when using multipathing/Round-Robin. Upon startup, the ESXi host hangs on for well over an hour. Changing the policy to fixed resolves the issue.
Our NetApp 2040s did this too. Hung at the vmx_vaaip_netapp screen for about 45 minutes.
MD series is currently NOT supported with 5.0. Dell has a firmware update coming.
edit: Not certified, I should say.
Definitely an ESXi issue. From what I've been reading it's affecting multiple storage vendors. Hopefully VMware can address this.
It's not a VMware problem. Several storage vendors do not yet have certified firmwares that work with the new login/iSCSI stack in 5.0. :)
The MD series is the most well known - a firmware update for them should be out shortly to address the issue. I don't have any information on EQL at this time.
Hmm I guess I'm just trying to understand why those storage devices are on the Vmware HCL(especially Equallogic). I know the MD series was there but was pulled off..
That's another story (starts with fat and ends with finger).
