Alright, I'm working on a case for my computer to immigrate to and I want it to have a clean, class, surgical look....ie: I don't want rubber mounts or whatever. For background, I've cut a hole in my V-tech X-focus case and a piece of Acrylic glass that I sized for it with 1" overhang on all sides. I figured there must be some kind of epoxy I can use to hold it onto the metal inside the case, and then use aluminum tape to seal it while it dries. I won't be moving this case much, so really, it doesn't have to deal with much abuse.
so the question is, Is there an epoxy that will bond my window to my steel case with reasonable strength?
