EPOX 8VTAI or 8KRAI-PRO - PROBLEMS! HELP!
sirenzero
i hope someone can help me before my body is found in my bathtub. Both AGP cards - ATI x850 pro and PNY 6600 lock up my system every 5 or so minutes, and cause my monitor to flicker anytime i play a game, or even go to a webpage, but with my old Geforce FX5500 everything is perfect. I have downloaded new and old drivers for both, used driver cleaner each time, reformatted 3 times, used 3 harddrives, 2 old one and one brand new one i just bought, i just replaced my power supply - a brand new Antex 500watt, ive cleared the CMOS on the bios/motherboard multiple times, i feel i have completely molested every bios setting known to man, ive attempt to upgrade/flash my bios thru EPOX except no new bios is available, ive tried hacked/tweaked drivers, resolutions, refresh rates, i have tried multiple different ways of plugging my power supply into the card, either card is barely warm doesnt seems to be overheating at all...i mean EVERYTHING im going nuts here. My monitor will flicker here and there, then my cursor will freeze and the computer will automatically shut down, or just sit there... If someone can help me PLEASE lol, im trying everything i can to get a decent agp card so my system can hold out a while longer....here are my specs below if they help:
Athlon XP 2800+ (not overclocked)
1.0 gig of ram (Crucial PC2700 DDR)
EPOX 8VTAI Motherboard
Antec 500w Power Supply
Two 80gb Harddrives (one maxtor, one western digital)
I have an Alpha heatsink with a black label on my processor, 4 case fans altogether, 2 in front, 2 in back. My temp via my bios monitor is steady all the time at approximately 55-58 degrees celsius on my cpu, and 25-29 degrees celsius case temperature.
My motherboard claims to be 3.0 8x compatible *also brand new board works great except THIS problem with any of the higher end agp card. My monitor is a 19 inch AOC Flatscreen i recently bought from Newegg...again everything runs 100% perfect with my older card, if there is something i am missing or anyone have any experience with something like this or my mobo, PLEASE let me know im going crazy over here...i have a $300 gift card to my local computer store and i cant even get a damn agp card to work....thanks - Matt
I used to have epox VIA chipset, I had AIW 9000 and I had to installed the VIA chipset drivers many times, the sequence of AGP driver also. I got it to work and I forgot how. I never buy any motherboard with VIA chipset again. Now I have GA with NVIDIA chipset, my AIW is working perfectly. ATI seems to have problems with a few chipset out there.
I think you have to load the AGP driver from VIA before the ATI driver. I had your problem and I forgot how I fixed it, but I think it's the order of drivers installed. Anyhow, good luck!!!
