Epox 8rda+ onboard firewire connection
imperator
Want to connect the firewire port on the front of my case with the onboard firewire controller but i cant figure out which wires go where. Hoping someone here has done it on his/her epox, or knows how the firewire pins are usually layed out.
I have a photo of my board here, and on the right you can see the wires and their markings from my case.
The manual might have the wiring diagram (like it does for the power switch and so on).
Also, after getting it set up right, the 8rda+ had some problems where windows wouldn't recognize the firewire drive unless it was turned off when the system was rebooted. You'd have to turn the device off, unplug and replug it back in,and then turn the device back on.
I'll look some more to see if I can find out how to wire it for you.
EDIT: Hah, found it right after I post.
IEEE1394 port header pins for IEEE1394 ports.
8 Shield o
7 Shield o
6 TPA1+ o
5 TPA1- o
4 TPB1+ o
3 TPB1- o
2 GND o
1 +12v o
Using non-EPoX brand cables on the motherboard if not properly configured may damage the motherboard. Use non-EPoX brand cables at your own risk.
