Epox 8rda+ Issues
Phelptwan
Well this is basically just a rant so if you don't wanna hear about by problems with this board hit the little x in the upper right hand corner of your browser now.
Over the last two years or so i've bought 19 epox 8rda+'s for customers. They all worked great and worked for about a year. This night i have replaced number 19. All 19, not half or a few of have blown capicotors. About 12 of the boards had capacitors blown around the socket area the others had capicitors blown around the agp slot and the bottom of the memory slot. Now i don't think i have done anything wrong with these computers. The computers had varying other hardware but the components that were standard were ATI 9000 video cards and Antec 350w PSU's with varying amounts of corsair value series ram. Now just to let you know these are not the only computers i've built and i'm far from a newb. I'm just looking to see if there is anybody else in the same predicament as me. By the way the majority of the epox boards were replaced with nf7's if anybody cared and so far not a single computer with that board has come back to me.
Oh and by the way dows anybody know a decent long lasting mobo without onboard lan. My dad wants to set up a computer for ProE Wildfire but the onboard lan on his computer prevents it from working.
From what I've read, heat greatly affects the life of capacitors. If these were close to the cpu - well, you know the rest.
Mines been in for 2 years, overclocked, albiet fairly mildy, all the time, and i havent had one single issue with it. If they were all using the same powersupply it may have been a compatibility issue. Did you buy all the psus/boards at once?
Yeah the heat thing is what i was told by the epox people/people in the epox forums and i actually RMA'd one board that was still under warranty...the others died a few days/weeks after the warranty was done so i just got different boards.
Nope. I bought them over the period of 3 months or so until the first one went bad. After that i stopped buying them. I looked over some of my sales forms and found that i had put enermax431's (thats what it says at least) in a few of the ones with more junk. The people at epox didn't tell me about any compatability issues either.
I have a 8rda+ board, and mine started failing beyond belief on november 8th, strangely the day I bought eq2 (I guess I wans't allowed to play :)). I looked into it, and what I found out was that the company who Epox bought the capacitors from, used an incorrect formula, perhaps telling it to hold more juice than it should, but in any event, it causes those capacitors to pop, making board to become unstable after 1 to 2 years. The capacitors that blow I believe have to do with filtering, but I'm not quite certain on that. I've personally seen 2 of these cases, mine and a friends. I also heard that epox does not accept RMA's if this is the situation, which is why I didn't try to send it back.
Epox will accept RMA's if it's within the warranty time but otherwise you're SOL. IThe three i've got sitting in my basement still are all rev 1.1.
My 1.0 and 1.1 rev boards both have bad caps. 1.1 board still works, oddly enough.
As far as ProE not working with the onboard lan.. Your board's onboard lan is likely borked. No modern motherboards come without lan. You're a bit SOL there, and it will in all probability work fine with onboard lan anyway.
EDIT: Something regarding licensing for ProE and LAN comes up. If you're trying to pirate ProE, get frelled. If it's an actual legitimate copy, then you need to use google and find out for yourself.
If anybody wants to take a look at the caps that blew here are a couple of pictures i took of them. I've got some better quality ones if anybody wants me to email them just pm me.
The older one i have.
The one that just died.
It is a legal copy of ProE that my dad is using for his home business but my dad had to upgrade his mobo to one with integrated LAN and now i can't get the licenseing server to work. It's ProE wildfire with something like lmgrd license server and it checks the onboard LAN's mac address before the LAN with the licensed mac address. I guess i'll probably have to get in touch with whoever makes ProE to fix it though.
I built around 6 systems last year with the 8RDA+. EVERY SINGLE board has blown caps. Soooo...I send one into Epox for replacement. They had the board for a month, NOT including shipping both ways. What a joke. HUGE mistake going with Epox. The other board makers aren't perfect, but this is the first time one has taken more than a couple of days for an RMA. I mean...how long does it take to throw my board on the fix pile, and ship me one off the fixed pile :rolleyes:
Well the person i use to send in RMA's says epox sends theirs overseas...I don't know if thats true but oh well. So lets see the count is up to 27 now.
If it licenses by MAC address, you could try spoofing the onboard LAN to match the licensed NIC. Try MACShift, a great, minimalist program that I have used on many occasions. (I should probably think about making a donation, if I ever get PayPal.)
