Epox 8K3A+ wont support Barton :(
CypHill
After looking at Epox's website, it seems my trusty 8K3A+ wont support a Barton 2500+. :( Has anyone tried it? Or does anyone have any hacked BIOS to support it?
I believe the difference between the 8K3A and the "+" is raid. It appears they run the same BIOS, raid or not.
Having said that, I have an early 8K3A that I've had for over a year, just flashed it to the latest BIOS late last year and I've been running a Barton 2500+ at 12.5x167 ever since the Barton dropped below $100. It shows up as an XP2800+ (I think, I can't say I've paid attention since the last BIOS flash).
There have NO compatibility problems, SiSoft burnin runs fine and shows the full 512K L2, UT and UT2K3 work flawlessly.
I can't say 100% that it will work in yours, but I wouldn't give it a second thought. I didn't.
The 12.5 x is what I got when I try to run it at 13 x. Not what I wanted but 12.5 is better than 11. I guess it is sort of unlocked. Multis higher than 13 yield nothing positive.
I'm using the latest one post on Epox, I believe late 2003, like Sept or October date. I've done nothing to this Barton except run the crap out of it.
So if I were to DL this Bios, and get the Barton, and run it stock (11x166), it won't show as a XP2500+ ?
I don't want to reboot mine right now but it shows overclocked as a 2800+ when the BIOS screen flashes. I haven't booted with the default settings in quite a while.
OK, I just booted default and here's the skinny:
BIOS = 09/16/2003
CPU = 11x166=XP 2500+
Let me ask you a question: This board has always shown a bit hot. I've moved my older chips down to the wife and kid computers and they always run cooler in their boxes than mine and mine is the cyclone machine. Small animals are sucked into mine. It always shows the CPU at about 10F hotter than any of the other machines in the house with the exact same HSF combos.
Does yours show hotter than normal or am I just freaking? After all, 113F for a Barton at 12.5x166 is nothing. My case shows 82F while other computers in the house show 85F Case and 100F CPU in an identically setup case and fan setup.
Good luck!
Will I do not have a Barton yet.. but with My 1600+ palomino OC'd to 2200+, it is pretty cool. I haven't tried this CPU with the OC and same HSF on a different mobo. My case too is a cylcone machine, with 2 120mm fans, 3 80mm fans, plus the Tornado that's on the HS. Maybe bad circulation even though you have a lot of fans? Try a duct or something to ensure airflow to the HSF. My old case created a dead space with no air circulation right over the HSF.. I corrected it and my temps dropped ~4*C.
I have actually tried the factory fan (Retail Barton) and it has the copper base, no difference between it and the massive sink and fan I'm running now. Also, both HS's were dead cool to the touch. The HS on the northbridge is hotter than the CPU. Oh, they were both lapped to a mirror finish as are all my other HSFs.
I ran it at default (because I was too lazy to reboot again) and it stayed at the same temp as the overclocked temp. I guess I should have done a base line along time ago rather than OC the crap out of it from the get go? ;) I think I'll leave it at 11 and see how high I can get the FSB. Perhaps the diode is too high in the socket. At least I know it is normal.
I also have an 80mm blowing directly down on the CPU fan from the outside. The air exiting out the back is only slightly warm, I'd guess something like the 80F that the case temp reads. HD is only slightly warm nothing is as hot as the old 486 I used to run back in them days.
Good luck with your bartonage, I doubt you'll need it.
