EP45-UD3P w all 4 memory slots filled
needmorecarnitine
how picky is this motherboard with all the memory slots filled?
I recently purchased a set of G.Skill Pi Black PC6400 used to replace my Corsair. Was thinking of getting another set (same memory) to get 8GB. I have tested my ram at its rated timings (4-4-4-12) using 1.9V (didn't try lower yet) and it works fine.
Is it like to work or not work, or, work if I give it enough voltage?
Would I just have to adjust the memory voltage or some other BIOS setting? This is the Rev 1.6 (motherboard) if it matters...
As far as I know intel chips are pretty good when filling all slots, you may not be able to overclock much, but at least it's not like the old amd's that downclock when all slots are filled.
I didn't notice any change in my overclocking ability with all 4 slots populated.
well, I run my cpu and memory at 400MHz so I should be OK there. Probably only small gains going to 8GB for my average use but since performance DDR2 ram is so cheap (bought used), I'll look for more memory
I have 4xGSkill Turquoise 4GB 1066/C5. Runs at spec with two installed, have to drop to 800/C5 to get four running, but that's in a crappier DS3L. Also, had to swap sticks around for about an hour to get it to turn on with all four sticks in, for whatever reason. That's with the Q9550 running on a 400MHz bus at 3.4GHz in the background.
