EP35-DS3L doesn't recognize 2nd Hard Drive*fixed*
rivacom
Has anyone else run into this problem? My main is a 250GB Sata II HD which has the OS partition on it. The second is a 120GB IDE drive, which is on the same cable as my DVD IDE drive. DVD drive works, and is set to slave , but no matter what I put the Hard drive to, it just doesn't work.
*edit sorry was a bad wire from the power supply.
