which would you all prefer to have and own?
screen quality (brightness, color reproduction) and resolution (1600x900) goes to the envy
as does gpu power and cpu options
battery life ought to be on par with no slice, greater on the envy with the slice, but then maybe not with all the low voltage chips.
size is in the mx11s favor, same with weight.
finish is more of a toss up, some people will prefer less going on, other will like the flash of the mx11.
Ok, so
+mx11 = smaller
+envy = more powerful cpu and gpu (dx11 for longevity), better screen res, brightness, color reproduction, optical drive
Ok, so
+mx11 = smaller
