Enthoo Pro + negative airflow
Maddnotez
Hello,
I have been searching around and from what I can gather this case stock creates a Negative Airflow Environment.
Is this accurate information?
If so, Is there a way to turn that into a Positive Airflow case?
You can control the air by what fans you use and where you put them. The case can be configured either way.
ok thanks,
So just make it positive myself.
Sounds good. I think I am going to get this case.
I had it narrowed down to the top 3.
NZXT H440, Thermaltake Core V71 and Enthoo Pro.
I would get the Luxe but from what I gather it is the same thing as the Pro but I'd be paying and extra $50 for LED's.
