Zangmonkey
- Jul 6, 2005
Other than price and capacity are there reasons to select enterprise spinners over prosumer SSDs in redundant arrays and virtual environments?
They're so different, it's like saying, what's better for transporting goods, flatbed trucks or train cars?
Enterprise - paying a premium for reliability and warranty
SSD - paying a premium for speed
Depends on which you value more. Google stopped using Enterprise drives, they found it was less expensive to have redundant consumer level hardware -- but if you have a situation where that isn't possible, then there is still a market for the enterprise level hardware.
Enterprise drives are really optimized for multi-user use.
There's no reason to get a spinning enterprise drive instead of an SSD for personal use unless you need capacity.
Can you elaborate on how SSDs would falter in the multi-user environment compared to enterprise drives? All drives are in storage array serving multiple virtualized environments with many users.
That's the exact scenario you would never want to use consumer grade drives be it SSD or spinning HDs for that matter.
You should look at "SSD Steady State Performance" tests/results to get an idea why you should never use them in an enterprise / multi-user environment.
Some consumer drives when put in a multi-user / enterprise environment will actually slow to slower than spinning enterprise HDs because they're not made for that mixed work load or the consistent use.
Consumer SSD tests are also done at 8GB span while enterprise are done at 100% of the disk and while both drop performance once steady-state is reached enterprise performance is magnitudes higher (especially Intel Enterprise SSD).
shush....SSDs can never be slower than a spinner![]()
Yeah, that may be. I kinda went back and forth on it in my head when responding the second time. I certainly didn't mean to imply that enterprise HDDs were better than consumer SSDs.
Do you have any links to thorough comparisons of high quality consumer SSDs vs enterprise HDDs in multi-user or multi-mode environments?
Well don't do anything on my account
I'm out of that game now and onto other things, but a couple of years ago I was thinking about getting a handful of high-end consumer SSDs and shoving them into some empty slots on one of our vSphere storage arrays to see how it went with one of our more IO-limited applications vs our aging 146GB 15k drives.
Don't be jealous that I know how to make suggestions based on the user work load and don't need to tell everyone they need the best 512GB SSD
What about for bare metal web/service servers?
What are you really going for here? Are you even reading the thread?
I am reading the thread, and most of what I've read focuses on storage density, reliability and certain multi-user workloads. Bit flipping is surely an issue for archival systems.
It doesn't seem to me that reliability and multi-user workloads championed by spinners and yet I see people here seem to be adverse to prosumer use in the enterprise environment.
I'm trying to understand what obstacles, other than price and density, SSDs still have to overcome for enterprise operations to implement them.
