We use Office Communicator on a completely Microsoft environment. That being the case, it integrates REALLY well with Outlook/Sharepoint and of course Windows. Couldn't really ask for anything more.
java.sql.SQLException: Network error IOException: Connection refused: connect
at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:385)
at net.sourceforge.jtds.jdbc.ConnectionJDBC3.<init>(ConnectionJDBC3.java:50)
at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:182)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.logicalcobwebs.proxool.DefaultConnectionBuilder.buildConnection(DefaultConnectionBuilder.java:39)
at org.logicalcobwebs.proxool.Prototyper.buildConnection(Prototyper.java:159)
at org.logicalcobwebs.proxool.Prototyper.sweep(Prototyper.java:102)
at org.logicalcobwebs.proxool.PrototyperThread.run(PrototyperThread.java:44)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:304)
at net.sourceforge.jtds.jdbc.SharedSocket.<init>(SharedSocket.java:255)
at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:310)
So I'm playing with this in my lab and I have users syncing up but the groups are not syncing.. Anybody want to PM me the details of that setup?
I looked at that, but it was before I realized I had LDAP signing requirement on, so after I shut it off, I forgot to check it again.I actually got it all figured out. Just took me placing it in the right baseDN for it to pick everything up.
But, even when it's working, I still don't show the rest of the users in the OU as offline.
Also, what is the benefit of linking groups, will it divide them up on the chat client per group?
Which property do you edit to show groups in the chat client. I can log in, but it's not showing any offline users or groups.I setup predefined groups so that in spark (I also tested it in Pidin) would automatically show up per department / function.
There is a checkbox to "show offline users" and also has a feature to cache offline messages, which is nice. So, I don't have something set right.It does not show offline users from what I've seen, they need to be online for them to populate the list. That's actually one of the things I like most. When using IceWarp + PSI it was great, but there were always crap tons of users offline. The lists on there were manual as well so users never disappeared off of lists.
Anyways, mine isn't even showing online users.
I don't have the ability to adjust that setting since I have no groups listed there. I don't know how to set it to pull them from AD. I have users set correctly to pull through LDAP since I'm logging in, but no groups listed.As for not showing online users, are you sure you're setting up group's properly?
Yep that's all the stuff I set up during the initial configuration.Here's an example so it can just blanket see everything, so you can assign whatever groups you want.
Host: "Server Host or IP goes here."
Port: 389
Base DN: dc="muff-factory",dc="local"
Administrator DN: [email protected]
I can log in multiple users into the chat client just fine. None of them show other users are online and none show any groups.
Thanks.
Yep, that's where I'm stuck at. If I have an Active Directory Security Group called "Group 1", how do I tell the Openfire server to display "Group 1" in the chat software.It comes down to the proper configuration of the security groups.
