Entering BIOS
godsend1
I just bough an IS7 from the f/s board and when it boots with a normal keyboard attached I get a cmos checksum error and no keyboard attached keyboard error message. It tells me to push del or f1.
I have also tried a m$ wireless desktop keyboard via usb and the keyboard error goes away. The checksum error remains and I don;t think the keyboard is functional until it gets to the os.
My question is: How do I get into the BIOS without a keyboard?
Thanks
even if the keyboard is USB, you should still be able to hit DEL and get into bios. My AI7 was like that.
however, What I'd do is make a bios disk on another machine and flash that board quick before it dies. don't mess around with those checksum errors, b/c one of these times it may display that and go straight to the prompt to insert a disk with a valid bios image.
the bios disk is easy to make. just a bootable windows 95 or 98 disk that is setup to flash the bios on bootup without user intervention. I think Abit may even have a util to do something of the sort.
Found the problem, a jumper from the ps2 power up was missing.
Thanks for the answer
