Finally I got my 4850 OC'ed to 825/1100 after changing the stock cooler to Thermalright's HR-03 GT. With the stocker cooler (it does the job well IMO), I was able to hit 750/1100 stable before, and my temp was at constant ~95C + 50% fan setting under full load.
With the new cooler pairing a 1600rpm 92mm fan, the chip runs quiet and cool @ 60C full load, and I gained 75MHz in core speed. The tiny MEM/VRM heatsinks were causing some heat problem at first, then it was resolved after I placed a 80mm fan blowing directly over them.
In the end I achieved massive 200MHz OC on my air cooled 4850.
Here is my 3dmark06 comparing link - 15009 points.
