Enough Power for a 6800 Ultra?
b1NARY73
Look at my Signature. I am going to use the step-up program, and want a ultra, but may just get a GT because of Power limitations. It would be a serious Pain in thre Butt to Pull my current PSU and Replace it. Let me know what you all think. I have a Antec True Power 380 Watt PSU that comes with the case. Thanks! :D
Matters what manufacture the Ultra is from will decide if it is enough. If it's a BFG, it won't be enough according to the manufacture.
he'll be fine...get over the nVidia power consumption bullshit.....i seen shuttles with 250's running ultra's and gt's so chill out rick
You could maybe run it, but you should probably plan on upgrading your PSU to go along with it.... 480W is quite a bit more than 380. ;)
I have a BFG 6800Ultra and I have an Antec Smart Blue 350W power supply and I have no issues. As long as you have a quality power supply you should be ok.
Do you have to REALLY have two full strands of Power available for the Ultra, or Can I have other things attached too them also?
it depends on what you have on the cable with the 6800U. if it's just a single HD or an optical drive, it should be fine, but i wouldn't put any high speed fans on the same lead.
I guess you guys are missing the point, so do what you wish. It is clear !!!!!!ism gets in the way of giving a correct answer.
To answer his question, no it is not enough power according to eVGA.
2Ghz Intel® Pentium® Pentium® 4/AMD® Athlon® or above CPU
256MB system memory
450 Watt or greater power supply unit
AGP 3.0 compliant motherboard.
A vacant PCI slot adjacent to the AGP slot.
Two Available hard disk drive power connectors from power supply that are connectd to nothing else in the system.
CD-ROM Drive
256MB system memory
CD-ROM Drive
I could care less what they say, I have an ultra running on a 250 watt, watts don't matter, its your 12 volt rail and can it sustain solid amperage.
they recommend a 450w PSU so all the people with 300-400w Powmax and Deer PSUs won't try hooking one up(they'll explode and potentially fry everything. they don't call it Powmax for nothing.). a good 350W PSU will handle a 6800U just fine.
felix88 said:
they recommend a 450w PSU so all the people with 300-400w Powmax and Deer PSUs won't try hooking one up. a good 350W PSU will handle a 6800U just fine.
Ditto
Fry everything........ :eek: My wife will kill me. II only have two fans, 2 120, one intake, 1 exhaust, so no high speed fans really. Maybe I should just get the GT.....but I want the Ultra pretty badly....hmmmm.
rancor said:
check out xbits labs power consumption article,
I suggest the purhaser look at the recommendations of the company who will supply the warranty and tech support versus a home brewed test. :rolleyes:
Do what you want man. Just remember companies don't make minimum specifications just to waste time. Nobody here recommending you use your existing power supply will provide any warranty or tech support like the manufacture, better yet buy you new equipment in the event of failure.
Buy the Ultra, get the correct power supply according to manufactures specs. Simple.
Rick, he wants to know if we think his PSU will handle the load. the people that have posted so far think it will. i'm sure he knows what the manufactures web site states, otherwise he wouldn't be asking this question.
b1NARY73, to address your concerns i will tell you that Antec makes very good PSUs. i wouldn't worry about it blowing up and frying anything, that is something the Powmax and Deer owners can worry about. if your 380w Antec can't supply enough power, you'll simply get artifacts, games crashing to the desktop, and possably a reboot.
Yes but with all the post on this forum about power supply problems, artifacts, studders, reboots, why go through the hassle? It is much easier to replace a power supply and video card at one time versus two separate times.
You don't see review sites testing with small power supplies for a reason.
http://www.hardocp.com/article.html?art=NjM1
i dunno about your case, but replacing my PSU would take quite a bit of work. if i could get away without spending that time, along with the money, i would.
i believe the PSU he has is capable of supplying 200+ watts on the 12v rail. looking at his system specs, he is drawing a bit more from that PSU than some folks, but i doubt he'll have any problems. if he does, he'll just have to buy a new PSU.
if you go browse the PSU forum, i'm sure you'll come across the "PSU calculator" Ice Czar posts somewhat regularly. use that to figure out how your PSU will handle the load.
*edit* here is that calculator.
http://takaman.jp/D/index.html?english
Rick....
He wants to know if he can run the Ultra on his PSU. The answer is yes. Why should he go out and spend another $100+ on top of his Ultra costs? Thats a waste of money. If my 350W antec can handle it then I'm pretty sure his 380W will.
Its been proven that an Ultra doesn't need a 480W PSU...does that spec keep noobs out of trouble when they try to put an Ultra in their e-machines...yes. b1NARY73 is asking, and we are giving him the answer...If you have a high quality PSU like an antec 380W then you should be just fine.
Thanks All, and thanks for the linky to that calculator. I am a noob when it comes to certain things, but I am actually quite Computer Savvy. This area happens to be one where I am a NOOB! :D I appreciate all the help. I am going to rewire and prepare for the Ultra to arrive ( Hopefully early next week) and if I have problems, then replace the PSU. Thanks Again.
