enough for SLi?
vexvegaz
will this psu be enough to power this rig and still have room for oc'n?
enermax 500w liberty sli
http://www.newegg.com/Product/Product.asp?item=N82E16817194003
DFI LANPARTY nF4 SLI-DR or ASUS A8N32-SLI Deluxe..still cant decide
2 x xfx 7900gt extreme
a64 3200 venice
x-fi extreme music
sony dru-800a
2 x 512 ocz gold
2 x 160GB sata drives
1 x 60gb maxtor
5 x 80mm fan
dual cold cathode
if not , recomend one thats $100 or less
also if possible, be in stock @ newegg cuz i plan on getting the mobo/ the 2 7900gts there
tnks in advance guys
I would imagine so. I've had people recommend me Enermax for my dual 7900GTX rig, your cards are a step below where I'm looking and you have single core on the proc, plus only 1GB RAM (maybe you should do 2GB as 2GB is rapidly moving to where 1GB was last year...)
update: ended up gettign the silverstone 600w psu and also took ur advice on moving to a 2gb ram and i must say..im soo glad i did that.
tnks
