GMoney42392
- Dec 19, 2005
i built my friend a new pc last weekend. it had the following specs:
c2d e6420
2gb apiva ddr2 800
8800gts 320mb
evga 650i
all inside of a coolermaster centurion 5 w/ window
the case has a 120mm in the front and an 80mm in the back, and the cu is cooled with an arctic cooling freezer 7 pro hsf. i was wondering if all that would be enough cooling to push his c2d to a 400mhz fsb and to also crank up the 8800 slightly while remaining extremely stable. if not, what would you guys recommend to increase cooling capacity???
c2d e6420
2gb apiva ddr2 800
8800gts 320mb
evga 650i
