Enough Airflow For BIX3?
roffle88
I'm finishing my planning on my next rig. The case is a DIY water-cooled(Storm,655,maze4-gpu,BIX3) Lian-Li V1200B modded with 5 intake, 5 exhaust(including 3 on BIX3). All fans are 120mm, 70 cfm fans. Is this enough to get the case at almost ambient temps with a 7800gtx and 4400+ severely OC'd?
BIX 3 is the Radiator that supports 3 120mm fans right? If so, then your fine. Don't worry at all.
Viper, your sarcasm is uncanny.
