- Jun 28, 2004
Welcome,
Your mission is to provide ideas for building an automatic fan controller.
The control system is as follows
Thermaltake Tsunami VA3000 case
Athlon 64 3800
MSI K8T Neo2 KT800 Pro
Thermaltake silent tower with dual 90mm fans
(2) Seagate 200gig 7200.2 drives
(2) Western Digital Raptors 74gig
Radeon 9700 Pro with VGA silencer and Tweekmonster Heatsinks (350 GPU /360Mem)
(2) 120mm Fans silverstar 110CFM@12V
This is the goal I wish to accomplish.
The Case (system) thermal control will be taken by a thermistor (20K) from the top of the case for the case temperature.
A thermistor will be attached to one of the Western Digital HDs for hard drive temp control .
Another thermistor will be attached to the base of the Athlon 64 3800 for CPU temp control.
The room temporature is 32 degrees C. With quiet and cool running on a normal day; 34 C is the normal temp for the system temperature. Case fans running 1250RPM ~7.5V
Criteria (Rules for design)
The minimum speed of the intake fan must always be higher then the exhaust.
Both fans must scale up to maintain the temp of the case within 4 C of the outside room temperature. The room never heats up over 42 C
If the hard drives are heating up then the intake fan will scale in voltage untill the hard drive temp have fallen or stay below 42 C
The Cpu fans speed must be automatically regulated and its voltage input must add in part to the system fans overall voltage output. AKA if the CPU fans voltage spikes fast (from a fast temperature change) then both the intake and exhaust fans are given additional voltage.
All voltage control points must be tuneable. That is for example how much voltage the case fans recieve from the cpu getting X amount of voltage must be tuneable.
If your going to use resistors try to keep the current traveling through the resistors low as improper use creates heat
PS I have already designed most of this system. I am looking for your ideas. Who knows maybe I have done something wrong. My final design will be posted for others to use.
My parts list so far,
3 thermistors (20K) 54C is the 0 resistance point ( all from thermaltake products, I have more if needed )
2 JFETS PNP style
(assortment of resistors)
2 potentiometers 10K, 5K
5 (diodes)
2 .10micro F capacitors
Prefab circuit board
Lots of molex connectors
Wire
Good Luck,
Mackintire
Athlon 64 3800
2 JFETS PNP style
5 (diodes)
Wire
Good Luck,
Mackintire
