Enermax Whisper II question
Did they forget to put the English manual in the box again?
DAMN!!! I hate when that happens....
For adjustable fan speed models: Tune the knob to control PSU fan speed. Fan RPM can be manually controlled or automatically adjusted according to system loading to avoid overheating.
Perhaps the only reference to the knob you have says....
Per i modelli di (ventoline) ventole a velocita regolabile: regolare la manolola per controllare la velocita della (ventolina) ventola dell' alimenatore. I giri/minuto (RPM) della (ventolina) ventola possono essere controllati manualmente o reolati automaticamente in base al carico del sistema per evitare il surriscaldamento.
Surriscaldamento.. Hahaha.. Crazy Italians.
Ice Czar said:
Surriscaldamento :p
I'll have to use that
somewhere
Tell a bella signora who doesn't speak Italiano that it's a hot sexy new dance performed by them prior to their best lovemaking sessions...and that you just happen to know it. ;)
Italian always sounds hot if you say things right.
