Enermax Thormax GT Full-Tower Case
HardOCP News
[H] News
If you need a full-tower case for your next system build, check out this review of the Enermax Thormax GT at Modders Inc. today.
Full-tower cases are sought after for the extra room they provide for system building but if size is the only thing they offer then things would get boring fast. With the market as competitive as it is, case manufacturers have begun looking into offering more than space and design cases that appeal to a lifestyle rather than be an all-in-one generic solution.
Nice case, but I'll stick with My Azza 9000B case or the similar on the outside GT1 case, since, massive is nice and all, but I like Enormous better and the two Azza cases deliver that in spades..
If the 9000B/GT1 drive bays and the rails for the motherboard tray were removed(not that I would), the Thormax GT could fit inside, now that's simply enormous..
Note: I doubt the 9000B/GT1 side doors could be closed on both sides w/another case inside, but the idea is that there is massive and there is enormous which is bigger still.
But then the 9000B/GT1 can fit a 480mm radiator(max of 55-60mm thickness, depends on the motherboard orientation) or a 420mm radiator with a few mods(added screw holes)..
