Enermax T40 or CM Hyper 212 Evo
I've heard there's some problems with the heatpipe design of the +
I don't mind paying $10 extra for the evo
The heatpipes are spaced farther apart than the evo. A couple degree difference...
Cool. I'm going to try out the open box T40.
What do you guys think of Antec Formula 7 thermal paste? I just got some for free and was thinking about using it instead of the regular old AS5.
I wouldn't use AS5 - it is capacitive, so can cause problems if you get it on the motherboard. The newer stuff is safer.
