Enermax Liberty PICS plz!
w00ty
well im about to get myself a liberty 500W for my Qpack but ive still got serious doubts on how exactly im gonna have to install it.
ive read some ppl have had to put it "upside down", wich means the fan is on the case cover side, while others havent...
so id really apreciate some detailed shots of ur qpacks
ty in advance!
Not really a big deal how you mount it. It runs cool and silent either way.
nice pic there
wouldnt u rather have the fan facing down though?
also, does that Zalman GPU cooler block the other PCI slot?
w00ty said:
nice pic there
I have it facing down, but I flipped the fan so it blows in. I also had to cut metal off the back of my QPack to get the Liberty to fit facing down.
Facing it up, without modding the fan, is perfectly fine. It still has to air suck on, it's not like it's blowing at the window...
im gonna have mine pulling air out as ive put the 12cm one as an intake, but ill place it facing down if its not too complicated.
why did u mod the fan so its an intake ? i mean whats the point in having hot air being pulled in?
Cooler air is outside your case, not hotter air. :rolleyes:
I'm WCing my QPack, so I doesn't matter. I don't want hot air coming out my PSU and going right back in from the 120mm fan. My radiator is mounted on the fan, so that would be really bad for cooling.
ahh that makes sense
as long as the psu doesnt run too hot i guess thats a perfect solution
wait... does that really make sense? :confused:
sure, the air from outside is cooler, but the psu gets pretty hot in my pack. having that hot air blow in has to be bad for it. am i missing something here?
The cool air blows in through the PSU and stock case fan on my QPack. Cool air that moves through the PSU will get warmer, yes, but not too much. It really doesn't matter to me, since most of my components will be watercooled, thus warm ambient air will have no effect on them.
Mark how much did your whole WC kit cost you? And what components exactly have blocks on them?
It cost me a little over $100, from Performance-PCs.com. Right now only the CPU will have a waterblock on it, but I'm looking into getting converters for my tubes so I can use a waterblock on my gfx card (my tubes are not normal size).
otherwise, the little pushpins that hold the qpack's top window in place would catch on it and I couldn't slide the case shut. My liberty fan is also mounted face up. It doesn't matter too much if you don't have much in the case..my cpu temps average 28C and HDD temps average 33C w/ a Zalman 7000 cpu cooler.
