Enermax Liberty cable length...
LoneWolf
Hi all...
If anyone owns an Enermax Liberty PSU here, I'd appreciate knowing the length of the modular and ATX cables.
My issues are described here. Basically, I'm down to two power supplies: The Enermax Liberty 400w or the Antec NeoHE 500w (I'd go lower with Antec, but you have to choose the 500 or 550w NeoHE to get the 8-pin EPS power connector used by the Intel BadAxe mainboard). I need to make sure cables will be long enough to reach where they need to in the Antec P180 case. The Enermax PSU is a good fit for what I want to do, and 20 bucks less (plus it's 3.3v/5v rails are rated a little better). However, I've already heard that the Antec unit will stretch as far as I need it to as cable-length goes.
Silly question, I know, but important. I don't want to have to send a component back. As usual, thanks for any help you guys can provide.
I can measure the length of one of the modular cables for you when I get back from work, if nobody else has replied by then. I have the 500W Liberty.
The Enermax Liberty works very well in the P180 case, from what I hear.
Thanks, dB. MJC, I appreciate any information you can give me as well. I think the entire Liberty line should have the same length cables, so that should be good.
