May 8, 2006 #1 R Rubycon Weaksauce Joined May 1, 2006 Messages 125 Is this supply worth opening to fine tune the outputs? Oops let me clarify. Is there a set of potentiometers in there to adjust?
May 9, 2006 #2 jonnyGURU Technical Marketing Manager at Corsair Memory Joined Apr 9, 2005 Messages 4,845 I don't remember there being pots. Why should you open it to adjust them?
May 10, 2006 #3 R Rubycon Weaksauce Joined May 1, 2006 Messages 125 12 volt seems low (11.5V) verified with hp digital volt meter. System is stable so will probably leave the seal intact. Bummer there's no pots though.
May 11, 2006 #4 jonnyGURU Technical Marketing Manager at Corsair Memory Joined Apr 9, 2005 Messages 4,845 +11.5V is low!! Make sure it's not just a poor connection at the PSU. 99% of the time low voltage is a bad connection when it comes to modulars.
May 11, 2006 #6 jonnyGURU Technical Marketing Manager at Corsair Memory Joined Apr 9, 2005 Messages 4,845 What you're doing is call thread-jacking. You're in the right forum, but your issues do not pertain to the original poster. The only similarity here is the brand of PSU. Create your own thread.
