Here's my Enermax Case Project. Just time for something new!
Here is the case before:
Here is what happened with the blow hole. I didnt like the look, so putting in a top window would be a good solution.
Piece of plexi & Planning:
I wanted to put a top window in my case to let more light out, since my case sits on the floor. I'm not gonna mount it yet till I figure a way to straighten the lines out. I've got a ton of sanding to do to make it look good...
I'm still trying to figure out what to do with the front. Any Suggestions?
Here's the side window I cut. I wanted to use the old plexi glass and blow hole, so here's what I did. It used to look like a flower. I cut the Left and Right pieces out.
I'm thinking about doing the following:
-Painting the Top and Bezel Metallic Blue ( the interior color)
-Paint the Whole Case a Different Color
-Putting Automotive Edging to hide the bad cut lines.
I'll post more pics as I get closer to finishing up the project.
Questions & Comments are Welcome!
-Ryan
-Ryan
