enermax 651 W fan censor
chuckm1020
does it matter if u have the fan censor plugged into the motherboard or not, for a powersupply?
according to this http://www.enermax.com.tw/product-01.htm the power supply is suppost do stay on for 2 minutes after the pc is turned off. mine doesnt do this at all. and i have that model, because thats the only one that is dark blue. go to that link then go over to the left of the page and click ax model with PFC. and thats the psu
No it doesn't matter, its just a means to detect the fan speed. If you dont care about knowing the PSU fan speed dont plug it in.
Just curious but what in the world are you running off a 650w PSU anyways? lol
i guess i like to have a really good quality psu that i can pratically throw anything at and it wont hesistate to be low on power:D . do u know why the fans dont stay on after the computer turns off?
Why would the fans need to stay on after the computer shuts off anyways? I dont see where it says anything about it in your link so i dunno. Do you have the 3-pin PSU fan connector connected to your motherboard so your motherboard can monitor the PSU?
