I got myself an enermax 485w ATX 2.0 PSU. The exact model is EG495P-VE SFMA.
I currently have an older motherboard (Asus P4T-E) which I believe is ATX 1.2. When I replaced my old power supply with the new enermax, the system wouldn't power up. Actually, it did power up briefly, before shutting down, and couldn't get power again. I believe this is to protect in case of any short circuits. Upon further checking the connections, I noticed that the 20 pin ATX connector is missing a white wire (I believe pin 18) on the Enermax. My old Aopen PSU has a white wire on pin 18. The Aopen PSU works, while the new Enermax doesn't. My question is - is the lack of a wire on pin 18 a new design for the ATX 2.0 standard, or is my enermax missing a wire? I haven't dealt much with newer model systems that use ATX 2.0, so I'm unsure if the wire should be there.
Cliffs:
- installed Enermax EG495P-VE SFMA (485W) PSU
- system won't power up
- checking connections, I see that the Enermax doesn't have a white wire in pin 18 (pin 18 is completly empty)
- replace with old Aopen PSU, system works fine.
- faulty enermax? or missing a wire due to new ATX 2.0 standard?
Cliffs:
