Stringfellow
- Dec 20, 2011
I still actively play Wolfenstein Enemy Territory on a regular basis, but notice that my frame rate isn't all that great. The game is pretty old, and the Sapphire 5770 should handle it easily, but I have watched the FPS counter go down into the 40s from 90. I play with screen at 1680x1050, but didn't notice any performance boost at 1024x768, or any other resolution. I am on Catalyst Version 2011.1012.1625.27603, currently. However, I used 9-11_vista64_win7_64_dd_ccc_wdm_enu for a long time, and tried the newer driver to see if the performance increased. The latest driver corrupts my fonts in Thunderbird, so I can't use it. Unfortunately changing the drivers did not help.
The AA, filtering, etc. settings are on, or close to, performance. I set it high enough to take the staircase bumps out of the roofs. Enemy Territory has the shadows off, but the lighting is set for quality. V-Synch is off. Tweaking the game settings/textures/particles/lighting doesn't have much effect, which leads me to believe it may be the video card. Does anyone know if these numbers are correct, or should the frame rate be a lot higher. I noticed if I force set the frame rate at 43 fps, the game gets really choppy. Any suggestions on getting better OpenGL performance out of the 5770?
Here are my system specs:
Component Details Subscore Base score
Processor AMD Phenom(tm) 9350e Quad-Core Processor 6.8
Determined by lowest subscore 5.9
Memory (RAM) 4.00 GB 7.2
Graphics ATI Radeon HD 5700 Series 7.4
Gaming graphics 2815 MB Total available graphics memory 7.4
Primary hard disk 468GB Free (596GB Total) 5.9
Windows 7 Professional 64-bit
System
Manufacturer System manufacturer
Model System Product Name
Total amount of system memory 4.00 GB RAM
System type 64-bit operating system
Number of processor cores 4
Storage
Total size of hard disk(s) 596 GB
Disk partition (C
468 GB Free (596 GB Total)
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives in RAID 1 mirror.
Media drive (F
CD/DVD
Graphics
Display adapter type ATI Radeon HD 5770 Series
SAPPHIRE Radeon HD 5770 1 GB GDDR5 PCI Express 2.0
Total available graphics memory 2815 MB
Dedicated graphics memory 1024 MB
Dedicated system memory 0 MB
Shared system memory 1791 MB
Display adapter driver version 8.902.0.0
Primary monitor resolution 1680x1050
DirectX version DirectX 10
Network
Network Adapter NVIDIA nForce 10/100/1000 Mbps Ethernet
Internet
768kbps/128kbps DSL
Motherboard
Asus M2N-SLI Deluxe
RAM
OCZ 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
SOUND
Creative 70SB073A00000 7.1 Channels 24-bit 96KHz PCI Interface Sound Blaster X-Fi XtremeGamer
System
Storage
Disk partition (C
Media drive (F
Graphics
Network
Internet
768kbps/128kbps DSL
Motherboard
Asus M2N-SLI Deluxe
RAM
SOUND
