I'm not sure if this is the wrong section to post this, if it is could a Mod please move to correction section, thanks. Anyway, I just got around to cleaning my garage and found an old system we had stored away and decided to convert it to a UTM system for my LAN, woot! So I decided to post a really quick tutorial on how to do this complete with pictures of the hardware portion and the software portion. So here we go, comments appreciated.
The Networking Hardware
The picture below is of a 5-port 10/100/1000 Switch, a 10/100 NIC (The bigger of the two NICs) and a 10/100/1000 NIC.
The way my system is going to be setup is as follows.
Internet Connection --> 10/100 NIC | Endian Firewall | 10/100/1000 NIC --> 10/100/1000 Switch
The Computer Hardware
Quick Specs
900Mhz PIII Celeron
384 MB PC133 RAM
4GB Maxtor IDE HDD
10/100 NIC
10/100/1000 NIC
CD-ROM for Install only
Picture of the RAM, Motherboard with CPU and HDD
Close up of the old motherboard
Alright, it's fairly simple to build a quick little system and if you need help with that, it's beyond the scope of this thread. Here are some quick photos of everything put together in the tiny generic compaq case.
Notice the button IDE cable with power, this is for the CD-Rom. I only need and want the CD-Rom during the installation. I much rather prefer running as little as possible. If you're wondering why everything is missing side panels or casings. It's because it's all old beat up hardware which is always a good candidate for linux applications. This pretty much concludes the hardware portion. Installing and configuring Endian Firewall is pretty easy, so grab the ISO from the sourceforge page and burn it to a disc.
I'm gonna grab lunch and post the rest of my guide when I return =]
Quick Specs
900Mhz PIII Celeron
384 MB PC133 RAM
4GB Maxtor IDE HDD
10/100 NIC
10/100/1000 NIC
