Majeztik12
- Jun 8, 2004
Just wondering if Intel is planning to produce future socket 775 proc. or is 1366 the future?
yeah 775 is basicaly dead though they will be releasing a replacement low end socket for i 7 processors though i forget what it is exactly...
S478 still isn't quite dead so I think that S775 will last for a couple of years yet. You can still buy S478 processors and motherboards although nobody would really want to build a new system out of it.
S478 is indeed quite dead. CPUs and motherboards for that socket are no longer in production.
That's incorrect. Intel still sells the Prescott 3.0Ghz processor and there are a few (albeit low-end) S478 boards in production. I'm sure that the Prescotts are coming from Intel's inventory, but the S478 motherboards are 'current'. Some links for your viewing pleasure:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116027
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130178
Dunno about you, but I got a helluva nice new PC setup with the "older" 775 socket vs paying the outragous prices for the i7. No thanks, ask me again in two years.
They are releasing in January new Quad core 775 chips. The Q9550s, q9650s, and one other. They are More or less the same chip but with much lower TDP ratings.
It's all relative.... If your computer does'nt slow you down and does everything you need... fast enough, then it's not obsolete. The I7 chips are nice, what's keeping sales down is the $300 motherboard and super expensive DDR3.
Yea I just bought a Q9550 from a forum member here. End of 775? its like saying dooms day was on y2k and were still living aren't we?
1366 is the new socket. Considering it has more contact points, its just better.
Just like PCI-E ended VGA overnight
to answer your answer with yes or no. Yes, it is basically the end. Just like PCI-E ended VGA overnight, the new LGA 1366 will be Intel's primary focus.
