encryption strength... which should I use?
ddoud
Even though the last guy seems to regret encrypting his zips...
I'm using FreeOTFE to encrypt some data, and I'm so used to a windows world that when presented with choices I get confused.
What is the most secure way to encrypt data here: http://www.freeotfe.org/docs/description.htm
Based on numbers alone, it looks like I would want a hash of SHA-512 and a cypher of RC-5 (AES). I'm new to it though, so names like blowfish and all are confusing me.
Basically, I've got a free drive and I'd like to play around. Can someone break these options down, and tell me what is most secure, even if it borders on weapons grade security?
Thanks!
d
From what I recall reading SHA has been broken (don't ask me how as I don't know).
I use a program called Truecrypt with the Whirlpool chiper and a Serpent-twofish-AES wrap.
Basically there are two parts (correct me if I am wrong on any of this if you know better)
you have the hash algorithm which will create your key used in the actual encryption from your password. Then the actual encryption method (blowfish, twofish, AES, etc..)
The differences come from the method they use to encrypt your data (heavy in the high math functions).
One more wiki link for you as I can't explain blocks
http://en.wikipedia.org/wiki/Block_cipher
Hope that helped :)
