I purchased an ENCORE ENRXWI-G Wireless LAN Extender from Newegg. It will not respond to its default address, 192.168.1.1, either from a browser or by pinging from a Command Prompt.
I turned off the wireless adapter on my laptop to avoid confusion with my wireless router since the router uses the same address (192.168.1.1). Using an Ethernet cable I then connected the ENRXWI-G to the laptop. The three lights (Power, WLAN, Ethernet) on the front panel responded correctly but it did not respond to its advertised address of 192.168.1.1. I tried resetting it to factory defaults to no avail. I even tried a second laptop thinking the Ethernet port might be bad but had the same result. Assuming the device was bad, I sent it back to Newegg and they immediately sent me another new one. The new one is also not responding.
Since the second one is also not responding I am now thinking I am doing something wrong but I am at a dead end when it comes to finding a solution. Any ideas would be appreciated as I do not think it is likely both devices are bad.
