Enclosure Recomendation
Juic3
Hi guys,
I am currently looking for a decent all around good enclosure, dont really wanna spend a lot but what I basically need and cant find is an enclosure that will work with desktop(IDE and SATA) and notebook hard drives.
Is theres such a gem ? Best if it can be bought at newegg.com
Thanks.
Well, notebook and ide drives have different interfaces and are typically different sizes. You can adapt notebook drives to work as a std IDE drive with some extra hardware. That's about it though.
I don't think an enclosure exists, but you might be able to work something with these. they are basically the same, just choose the manufacturer you prefer.
Sabrent
Masscool
Vantec
Thanks a lot for the help guys !
I guess I'll jump on the Sabrent model.
