enamal on plastic?
ForeverUnknown
can i use enamal to paint plastic or do i have to use laquer? oh and can i get a mirror finish on plastic like i can on metal?
Well I just asked the just about the same question and got as much of a responce. I can tell you what I've used on my last 2 paint jobs. I've uses Rust-Oleum Appliance Epoxy (Ultra-Hard Enamel) And once it's dry ( takes about a week to fully hardden by my guess) The stuff is hard a shit to do anything to. Unclusing sand off. And It will bring to a mirror finish.
Here check out this linkage. They both used Laqures I think thou.
http://www.pc-workshop.net/articles/paint101/paint101-1.shtml
http://linear1.org/gm/archives/00000156.php
Follow thier instructions and you cand lose. The bottem one has other stuff on his page worth look'n at. And of corse post pictures when you're done.
i think i'm gonna try enamal on a front cover i dont use and see how it turns out. thanks. it'll be at least 2 weeks for me to finish so not toobad
Warning. Do not use primer with enamels. If you read the can it says so.
